Best headers in a early abody?
1968fish
Bend Oregon
Would like some of your guys opinion on early abody small block headers? 1965 dart with 340 and 904?
Thanks
Early A-bodies are an even tighter fit than most common A-bodies (Duster for example) which are already known as a very tight fit. I have Hedman shorty headers on my Duster, with Pro-Kote ceramic coating in Indianapolis which I highly recommend. The fitment is excellent and looks extremely clean. A shorty header will be an improvement over manifolds (and will require a mini starter) but they will not make as much power improvement over full length headers. You might get 10 hp versus the 20 hp a properly matched set of long tubes will provide, but they are so much easier to deal with. Since they are block huggers, they should fit pretty well, PS and PB no prob. Also strongly recommend the fel pro graphite/paper header gaskets and ARP stainless bolts with anti sieze. Those Mopar 5/16" bolts are barely sufficient for the job so don't go cheap on the bolts, ARP is a smart spend.
I run Hedman Hustler fenderwell headers(1 7/8 ) in my Early-A 66 Dart.TTi sells under chassis 1 3/4 step headers now.Good luck.
Where was your supplier from Scott, I need to get a price on a set of feder well headers
I don't want to deal with low hanging and a tight fitting header myself
Keith (66340SEDAN) as been running a set for a long time, Victoria is going V8.
Hope it's ok to jump in on this thread :glasses7:
Thank you once again my Canadian friend, I will check in to it, for 2 ta 300 more
I will be glad to have these in and dun..:color:
Any one have any they want to sell??
There is a member that has some for sale, here some where but I can't find them now, After all the work and cutting is dun it would be very hard for me to put used one's in, if I remember right he was asking $375.00 for them but never said what they fit.
