Here's how Mopar ignition switches work:
There are three important wires involved
1 When you twist the key to start, one wire, commonly yellow, fires the start relay which receives a ground through the neutral safety switch (if auto) The contacts of the start relay then fire up the main solenoid on the starter.
2 ALSO in start, a SECOND set of contacts in the switch feeds power out a SECOND wire, normally brown, which feeds 12V directly to the coil. This is known as the "bypass" so the coil makes a hot spark in start. Chrysler calls this "ignition 2" This circuit drops out when you release the key to "run"
3 A THIRD set of contacts in the switch MAKE when you RELEASE the key back to "run." This wire, normally blue, feeds power through the ignition resistor. Chrysler calls this "ignition 1"
So if the resistor is bad, the brown will feed the coil as long as the key is held over to "start." IT IS POSSIBLE (I don't know) that the contacts in the switch may "drop" the starter out first, leaving the brown "bypass" circuit engaged
GM products and Ford products accomplish the "ignition bypass" by means of the solenoid. On earlier GM and Fords WHICH USE this circuit, the GM has 2 small terminals on the solenoid. One gets power "in start" from the key, the other terminal feeds OUT 12V when the solenoid is fired to power the coil. Ford works the same, except they use a fender mounted (improperly called solenoid) it's actually a huge relay or contactor.
