Best motor mount for a big to block hot rod
SnowDrifter
lotus
What would be a good strong rubber mount for big block to hot rod frame.
I think your going to have to go full custom.
On the pass side you could invert a spool mount. On drivers side you have tons of room
Start bending up steel
For my 66 Dart, I cheated and just bought some weld-on bushings and just attached them to some stock big block engine mounts.
https://southsidemachineperformance...d-on-4-link-bar-end-w-poly-bushing-dom-tubing
Granted, the bushing is poly and not rubber, but you said it's a hotrod, didn't you? Here are a couple photos of what I did for ideas. You could easily make something similar with stock biscuit or spool mounts though. You just gotta get creative, grab some metal, and get busy.
Just curious, is there any frame left up front?
Every time I go to a bigger motor I seem to get it pushed further into the cab and lower to the ground I have lots of room up front. 15" crank pulley to radiator.
I guess those make good strong motor mounts for big blocks They look pretty clean
