fenderman33
I'm putting my 1994 5.2 Magnum back together to go into my 73 Duster. I'm going to run the stock cam, intake, & EFI, with a fresh valve job and unshrouding in the heads. What's the best way to bump up the compression while it's apart? Mill the heads down, deck the block? This will be a street car, and I'd like to know what I can get away with and still run on pump gas without a problem.
Thanks,
Jon
Thanks,
Jon
