Best way to lift a slant 6 engine block ?
unclebear
Member
Amherst ,Va
Hello all , I have my engine on a stand right now and will be installing it shortly .
What is the easiest and safest way to lift it ?
I had a chain under the block at the front and bolts in the bell housing for the back . It came out, but it was quite awkward and tilted a lot .
I have not done this for a long time. I do have the use of a nice lift though .
Any advice would be appreciated .
For Mopar, Slant Six - Engine Lift Plate | eBay
Last time I put the engine in my Colt I used the top of the head bolts AND another chain down to the trans brace bolt bosses.
This kept the engine at a 30 deg. tilt and it went in like butter.
If you just use the top bolts at some point you have to twist it over to align the bellhousing.
Best way to lift a slant 6? With Hulk Hogan & three of his friends......
I am sorry for the delay guys, I ran out of the 3/8 bolts. Everything is shipping this weekend. PM me here if this is causing and grief.
