69 valiantguy
Member
First time on here. Had hot rods my whole life mostly b bodies,can't afford them anymore. Came upon 69 valiant signet 48000 mi 225 leaning tower of power 9 in brake car runs great. Upgrading to 451 six pack 915 heads 2.140 intakes 1.88 exhaust ported til it looks like you can pitch a cat through them.roller rockers Manley stainless valves,valve guides bobbed cut for viton seals to be good to .600 lift. 530 block bored .030 studded mains 440 forged crank with cut mains & bobweights ly rods, all balanced mahle pistons & rings haven't decided if i'm going flat tapped or roller .tti long tube in chassis headers msd6al ignition blaster coil,727 3000 stall 3.55 8 3/4 spool posi 8in big pattern weld drag lights. rear disc's off 96 grand Cherokee front disc brakes off m body 3 1/2 welds good year drag skinnys, 275 60 rears with springs relocated here's the pics so far
