Big block A body 4 speed Bellhousing
jtkaaa07
BossMan
Neenah Wisconsin
Guy's, I'm thinking about put my 383 in the dart, and want to go with the 4 speed, what bellhousing will work, and what are you guy's using?
Thanks Jeff
The factory casting number is 2468372 and 2468370 will also work with no issues, the rest of the parts needed are sold by Brewers. There are others that will work, but these are the factory numbers, also used on 65-69 C-body's as well.
You need a 10.5" clutch/ belhousing.
If your starting from scratch this is the best fit. As mentioned above, 370 or 370 casting numbers work. 513 alum bell will also work with an adapter ring or retainer change as that one has the 4.805 retainer register. We also make new 10.5" bells with both size retainer bore's, often less expensive than guys are asking for used ones that need threads repaired.
Thank’s Dan, yes I just seen the new bellhousings on your website, what clutch fork works with them?
