carfreak6970
I am not to sure if this would go into the suspension and steering or the big block section. But since it appears to be big block specific I will post it here.
So I was looking around for parts for my 67 GTS project (383) and came across this outfit called classic industries. I downloaded their catalog and was impressed with the variety of parts they had. I got down to the suspension section and first saw how outrageously expensive a 67 idler arm is, but noticed they sold a 383 specific pitman arm. I find this a little odd because if the pitman arm is different enough between big block and other engines, so should the idler arm, but they didnt have a specific big block idler arm for a 67 listed. So I go and check the 68 parts book and behold they do list two part numbers for pitman arms, one for 6 cylinders/small blocks and one for big blocks. However the part number for the big block pitman arm had a asterisks next to it meaning that is used on an as needed basis.
Was there a difference between the regular pitman arm and the big block one? Why would the pitman arm require a different part number and the idler arm not? Would the different pitman arms be interchangeable? since it is listed as an as needed basis, why have two different ones? what did one buy you and the other lack in?
