big block bell A Body part numbers...
frederick_76
Milton, Wa.
As I understand, there are 2 bells that I can use. Can anyone post the part numbers for me? 1967 Barracud, 440, 833 4 speed. Thanks, Dennis.
You can use any big block bell with TWO ball stud holes for the linkage IF you are going to run stock clutch linkage. You can use any other big block bell if you are going to use hydraulic or fab up linkage. The bell and trans front bearing retainer need to match.
