big block carb size
Rolling_Thunder
Rolling Thunder
Los Angeles, CA
i need recomendations on carbs for my engine... it is a 383 with the 284*/284* - .484"/.484" camshaft and ported 906 heads... should i be running a 650cfm ?
I personally would rather see this engine with a 750 cfm carb. I think it would respond much better. I'd rather see a 650 on a mild smallblock.
another vote for the 750. Or you can spend $100 on a proform main body.
Your biggest spec for picking the carb is the max rpm you will hit in shifting and driving to pick a carb size.To figure the size you need,RPMxengine displacement/3456x0.85%= the carb you need for the street.Mrmopartech
Holley or Edelbrock? Either. Some people like one some like the other. Personally I like Holley because of the number models available and they just plain work awesome.
On the other hand, I just put a Thunder series 650 AVS on the engine i built for a friends 69 383S Barracuda and took it for a ride. Let me tell you that is an awesome street carb. Right out of the box,stock A-body big block exhaust manifolds, bowl ported heads, Comp Cams extreme energy cam. KB pistons. 4-speed. Runs flawless. Very responsive. May have to have one for my street car. I wish they had it a 750 though.
I run a 1050 Dominator on my 383 but I have a larger roller cam and 4000 rpm PTC converter along with 11:1 compression. I'd run a 750-850 on yours.
