I have a big block K Frame that is in need of some attention. I am contemplating taking the engine mounts off and putting them on my small block V8 K Frame is this possible has anyone done it?
Thank you that makes sense to hold it perfectly square so that when you put the motor mounts back on everything’s in the same place and heat doesn’t move anything.Very possible.
IMHO.
I would build a metal jig that attached to all 4 of the k frame mount holes and then attaches to the motor mount flats and misc holes.
Sacrifice metal on the old k member when you cut the mounts loose, then move the entire apparatus to the new k frame and start removing bits here and there till it sits on the 4 mounts and then weld it all in
not if the BB K is rusted! (just a guess)and modifying an actual bib block k sounds like lowering value of both...
