Jun 25, 2022 #51 George Jets 1967 Dart 2 Door FABO Gold Member Joined Jan 18, 2019 Messages 11,586 Reaction score 16,385 Location Palm Bay FL Stock VW 1600 cc engines valve lash is set at .004 - .006 ths. Aluminum Heads, solid lifters and adjustable rockers.
Jun 25, 2022 #52 B Bewy Well-Known Member Joined Jan 1, 2021 Messages 7,018 Reaction score 4,764 Location Australia If these were all new parts that were just getting aquainted with each other, then stack of tolerances could account for a 3-4 thou change without anything failing. More noticeable with 1.6 rockers.
Jun 25, 2022 #53 PRH Well-Known Member Joined Dec 14, 2018 Messages 6,609 Reaction score 11,421 Location So. Burlington, Vt or the fact that cold in January vs June makes a difference Click to expand... I wouldn’t rule that out. To see if the lash is holding steady, the before/after checks should be at least at “similar” air/engine temps.
