Big brake upgrade for a 1971 dart with original KH front discs
elbert79
Active Member
Norway
Looking to upgrade the brakes on my 1971 Dart which has original front discs with KH calipers.
There are kits for drum to disc available but i haven't found any disc to disc. As I'm planning a gen3 hemi swap i need bigger brakes to get it approved with the higher power output. So I'm looking for 12in + rotors.
The Cobe-style 13" Front Disc Brake kit looks interesting, guess I would need to replace the spindle to a 73+ one, or hare there a bearing kit/shims/sleeves available to use the 73+ disks on an earlier spindle?
Am I correct that it uses Ford Mustang Cobra dsics and callipers? Anyone know form which year those come from?
I would call or email him with what you have and what you want to accomplish. He isn’t going to steer you wrong. I have his 15/16” master cylinder, factory power booster, and KH discs. When I upgrade to bigger discs I will remove the power booster, the 15/16” master cylinder makes that much difference.
