[SOLD] Big fall garage cleaning
DART5770
Albert Lea, MN
MOPAR Race & Street Parts:
*NEW Hoosier 28-4.50x 15 drag race front tires. (2) (reg $155 each). $250 for the pair!
*Near New: Edelbrock Victor 440 intake manifold. RB engines 413-426-440. $200***** SOLD******
*SB Mopar cast iron Econo W-2 heads with Mopar valves, 2.02" & 1.60". No springs or retainers. Casting #3870810.
Have been hot tanked and mag'd. Has bronze-wall guides (spiral type) Only minor bowl blending. Little use since
brand new. ****$800 *** Have springs and retainers available to complete.
*Holley Strip Dominator. SB Mopar W-2 head oval port intake manifold. $175
*Holley Street Dominator. SB Mopar W-2 head oval port intake manifold. $165
*NEW Holley Strip Dominator SB Mopar W-2 head, SQUARE Port intake Manifold. Also fits Indy 360-1 Heads. Never bolted on an engine. ****CALL****
*TCI Street_Fighter shifter 727-904 torqueflite. Forward or Reverse pattern. $100
*GIBSON STAINLESS STEEL headers for Dodge Ram, Dakota, or Durango 1996-2003 with 318 or 360 engine. 2wd or 4wd. Excellent condition.
The elite in late model headers, part#301-S. Thick 3/8" flanges, rust through prevention from stainless steel. Fits stock Y-pipe. Shorty design.
Headers have been glass beaded and painted. Headers sell new for $525!! A steal at $250 for the pair.
*New Moroso oil pump pickup for BB Mopar pans Part #24750. $25
*Pair BB Mopar '346' head castings with OE stock valves. Same as '906' or '452' heads. Milled approx .080" - 78cc chambers. Approximately 10 cc's
smaller than stock and comparable to 915 closed chamber heads. Fresh, but older valve job. Could use 2 seats. AS-IS $250 OR with ALL NEW
Bronze guides, 2 seats installed and fresh multi-angle valve job and springs, retainers, & positive seals completely assembled with tip height and
spring installed height set. *****$695.
*Pair of STRANGE ENGINEERING 35 spline Pro Race axles for B-Body, 8-3/4" or Dana 60. Comes with
1/2" x 3" long studs and 'Green' ball bearings. Came from low horsepower car, splines are perfect! NICE!! $325 Over $500 new.
*NEW TRW L2316F-20 forged piston set with pins for 340 Mopar +.020".(missing tru-archs.) Flat top 10.25 comp. $325.
*Used LOKAR 727 torqueflite braided dipstick and tube - firewall mount. $50
*Milodon Deep pan and pickup for 318-340 cars. $90 *********SOLD**********
*Milodon deep pan and pickup for 360 or Magnum engines - cars. #30940 & 18345. 8 qt. 8-3/4" deep.
Some modifications. $185
*Factory 426 Hemi rods, used, singles. $50 each.
*426 Hemi race pistons, singles, Venolia & TRW 4.280" bore. $25 each.
*MANTON 3/8" heavy wall pushrods for 440 with hydraulic cam and adjustable rockers. $125
*NEW Elgin 3/8" chrome moly pushrods for 383-400 with hydraulic cam. $75
*VDO 9000 RPM Play-Back tach with shift lite and instuctions. $160
*NEW Mickey Thompson 28.0 x 7.5 - 15 Sportsman front tires. pr. $240
*Weld 15 x 10 Pro-Stars. 3-1/2" back space. 5 x 4-1/2" bolt circle, Mopar & Ford,
with new Caps. pair. $300
*Hooker Super Comp headers for SB Mopar B & E bodies, part #5115. Nice shape, were drag race
only, no street use. Has 1/8" holes drilled for thermo-couples near flanges. $450 new!
$150 AS-IS or $200 with holes welded.
*340 +.030" forged pistons, Full dome 12.5:1 compression. Litened and gas ported by Patterson
Racing. For .990" wrist pins. (not included) $250
*SB Mopar head stud kit $60
*NEW Hyper-Coil coil over springs 14" x 2-1/2" 300# $100 pr
*used Grinner II power glide trans-brake valve body with solenoid. $125
*Power glide Aluminum trans shield for deep pan. Good condition - SFI expired. $50
*NEW Mopar Performance 3.9 V6 Head gaskets. $10 pr
*Biondo Racing Air cylinder throttle stop/ throttle controller with air cylinder, solenoid, and CO2 tank and regulators. $125
($259 New)
*NEW 727-904 Torque-flite 5.0 Ratio band apply rocker *****$25
*NEW Mopar Performance Leaf Spring Perches. In the box. *****$15
*Barry Grant 1/2" 4-hole wood spacer for 4500 Dominator carbs. *****$20
*Used K & R Delay Box - - Early Model - - Model XTC-200 with Throttle stop, Delay & Cross-over. Works!! *****$50
*Eagle Big Block Mopar 7.10" H-Beam Rods ---4 only---$50 Need spares or complete a set?
*ARIAS Small Block Mopar 340 PISTONS, +.040" --4.080" Bore, 13.0 Compression, 547 grams, 1/16 x 1/16 x 3/16" rings, .400" tall dome,
With Tool Steel Lite Weight Pins, For .990" BBC pin size. Must hone rod from .984" to .990". (More pin selection available for .990 pins than
SB Mopar). 6 used with less than 100 runs on them and 2 NEW. Pistons new were over $650 and pins $200 + honing pistons for pins.
1/2 price *****$450 OBO.
*NEW Chrome Small Block Mopar Chrome Valve Covers *****$30 pair.
Thanks.
Call 507-373-5907 days Or you can email at tljjhest@charter.net
Can supply more pictures of interested parts, but may take 24 -48 hours. Please be patient.
Parts can be shipped by UPS or USPS at actual cost.
Cash, Money orders, Pay-Pal or ?
***ALSO LOOKING FOR 6.1 HEMI PARTS******
I assume this is in excellent shape . "Used LOKAR 727 torqueflite braided dipstick and tube - firewall mount. $50 "
I will take..just need the shipping to Nova Scotia B0P 1T0 and your paypal e-mail.
Thanks
Ian.
Can you send me a photo of the headers please? I have 72 Challenger with a 340.
