rah64dart
Who is the best big block builder on this site ?
lol. there are many here.
but, if you have about $80 thousand cash google "goodwin semi hemi"
you can order up a 600 to 820 cubic inch hemi stroker lol
yes way more satisfaction following rusty's suggestion
http://www.amazon.com/dp/1557881901/?tag=joeychgo-20
x2So the logic here is pay someone for all the machining and then put it together yourself?
SMH..
Well my logic is pay the small assembly charge and have them break it in on the dyno. Most good engine builders stand behind their product. I know mine does. You assemble it, not their problem.
So you are into it for what? An extra 1,000? Seems worth it's weight in gold to me and given the cost of an engine build and the cost of one of these cars, it's pennies on the dollar.
SMH..
SMH..
SMH..
Yeah, I guess if you don't have confidence in your own skill's or perhaps have more money than you need, that would be the way to go.
it's not to save money
it's just for learning / enjoyment / satisfaction etc.
by the time you buy the tools you need any money saved would probably be a break-even. ring compressor, mic, dial mic, calipers, plastigauge, cleaning supplies, gasket sealer, anti seize compound, white lube, etc.
you definitely would do it with guidance of a machine shop buddy if it's your first time
