Biggest Cam in a 360?
I have a mopar performance .455/272' in a stock low compression 318. Runs good and a little lump to its idle.
I run one of those...nice chop to it!!
[ame="http://www.youtube.com/watch?v=V9NlGCXBagg"]First fire up of the '46 Dodge rat rod pickup - YouTube[/ame]
Well going for sound will usually lead you to disappointment.But, If you want your motor to sound like a pro stock car (LOL) then use one of the dreaded .509 purple cams... wich could actually work well in your 360 with the right gear and converter.
this wouldn't be the biggest, but it really does sound good and your neighbors will hate you.
I'm wanting to run a big mother thumper cam what changes will I need to do if I want to put it in a stock 360
Rear gearing would be a good change. Depending on what you have now for gear. Intake is another option to change. Converter if stock better off with quality higher stall unit.
I love seeing posts get brought back from the dead :usflag:
XE284 I used back in the day. Turd down low even with 3000ish stall and 3.91's.
