No precision was used in this process at all. You could look at 30 different core supports and all will be different.
Basically, you want black from headlight to headlight in the area behind the grill including the latch support and lower core support.
If you mask for over-spray and your black has nice sharp edges from the tape lines.... You did it wrong for a factory appearance.
