Black suede dash paint success!!
Butchie7284
Wilkes barre pa
So I'm almost done with the interior pieces for the duster. I'm at the point to spray the dash frame and decided on I using the RM Diamont brand for the dash frame only. My paint guy took 2 weeks to do some research on the original code for me and came across a color that is nearly identical! What you guys think? I sprayed the color on a spray out card and put it up next to the clean original paint that was sorta preserved under the glovebox door trim.
X2
Looks like a perfect match from here. Nice work.
Was this mixed for you from a code or by eye?
I need to do a dash frame soon myself. Would be great if you had a code to share.
This is what I used. It was mixed 1:1:10% (paint:reducer:hardener). I sprayed 3 wet coats over a gray 2k sealer. The final 2 coats were mist coats. So a total of 5 coats. I sprayed it out of an Iwata lp400. The paint formula was #4441 and its from a 73-75 plymouth
