Jan 11, 2012 #1 SleeperScamp Well-Known Member Joined May 8, 2006 Messages 2,081 Reaction score 61 Location Texas 1970 340 Duster factory a/c.. Blower works on low only.Even when switch is on high it still just blows on low. Where do I start?? Thanks in advance..
Jan 11, 2012 #2 67Dart273 FABO Gold Member FABO Gold Member Joined Oct 14, 2010 Messages 62,697 Reaction score 37,144 Location Idaho You sure the motor isn't dragging?
Jan 12, 2012 #3 SleeperScamp Well-Known Member Joined May 8, 2006 Messages 2,081 Reaction score 61 Location Texas 67Dart273 said: You sure the motor isn't dragging? Click to expand... I'll check that out.. Thanks.
Jan 12, 2012 #4 340sFastback Well-Known Member Joined Mar 25, 2007 Messages 5,644 Reaction score 3,974 Location Maryland Could be switch. Hook 12 volts directly up to it. The wire connection is in the engine compartment. Then see if it spins fast. I believe there is also a blow motor resistor which could be causing problems.
Jan 17, 2012 #5 ken5124 65 Valiant Signet Joined Feb 18, 2007 Messages 615 Reaction score 106 Location Winnipeg, Manitoba Probably the resistor, mounts on the top of the heater box.
