- Joined
- Jan 8, 2012
- Messages
- 7,098
- Reaction score
- 4,247
Only the regulator, first time alternator of natural causes.
This is the points type regulator
What harness did you use? Is there any premade kit that is plug and play or did you use an universal kit?
Going to go tinker with it as I got the new regulator, read somewhere about adding an additional ground wire to it, so I will try that and put an wire between the regulator and the engine block/firewall ground.
M&H.
