Blueprint 408 Stroker Questions
jeh
Seattle, WA
Hey guys, looking for anyone who has experience with these to answer some questions....
what style timing cover comes on these things? Oil Pan?
Do I need to get a special flexplate to hook to a 727?
any other issues?
anyone setup theirs w/ a serpentine system?
thanks.
any other issues?
thanks.
I have the one with the Eddy heads.
It has the standard aluminum 360 timing cover.
You need a weighted 360 converter, or flexplate.
Rear* sump, 6qt. pan.
I'm using stock pulleys, no issues with the motor at all. I'm at the 1500 mile mark.
It was dynoed at 467 HP, 500 torque. I'm satisfied with it.
I am going to swap the flexplate with a weighted B&M one I purchased. I'm going to switch back to a neutral balanced converter I had in my 340. I don't like the stock 360 flexplates.
Hope that helps.
Hope that helps.
Nice #'s i thought they came 375hp w/460ftlbs?
So what did you change or was it just the heads?
