NorthernSwede
Anyone knows the correct bobweight for the P5007256 4-inch crank?
Eagle cast cranks in a 4.00 or stock are in the neighborhood of a 2050g boboweight. so if you can get your formula for rotating mass - big end and bearings- and reciprocating mass (everything else) and get it very close to 2050, you should be within 1 slug of mallory or even lightening the crank. They say cast are for external balancing but there is nothin gto say that they cant be internally balanced if the bobweight is less than the throw weight. Forged cranks are heavier by nature so they usually need to be lightened, cast are lighter so more mass needs to be added to deal with beefy rods and old OEM mopar lead like pistons.Well I want to know how much the assembled piston and rod should weigh to get the crank balanced right.
Yes there is a target bob weight that the crank was designed for, that doesn't mean it can't be changed. Lighter is better, less stress on all the parts involved. I would never choose rods and pistons based on the target bob weight. It would probably require less work to balance but so what, it's not that expensive to start with.
the bob weight for my 408 ended up being 1640 with scat i beams and diamond pistons i am using a scat forged crank and my machineist said they had to take nearly 400 grams out of the counter weights it should rev to the moon i hope
