Body Panel Interchangeablity
73dart_swinger
i have a 73 dart that i need some body panels for. i know i will need a door from a 73 since the window is different. will the front end fit on my car? ill have to have a hood, the fenders, grill, and bumper, right? it might be nice to ditch that heavy front bumper. i just was wondering if the body lines would line up and if it would fit from a 67-72. also, are the 74-76 front ends the same? thanks guys.
The body lines are the same,i have friend that used a 72 Dart front-clip on his 73 Dart and didn't have any problems with it.
He also used the 72 rear bumper.
As far as i know they are all the same body lines from 67 to 76,although i am not positive.:-k
the problem i have found isn't the body lines or the window exactly but hte placement of the door handles INSIDE! on the 2 drs they were higher up near the window instead of down with the arm rest. as far as using the older bumper you may have to swap clips for it to fit right but even that should bolt over no problem
I forgot about the inside door handles being in a different position!8-[
