mopar56
so short story version, ( long version, follow threads in slant six section under " holley 1bbl flooding") this carb has been off and on the car for a rebuild and series of adjustments several times, anyway for the most part, the car runs well now, choke works fine, idles well, only one more instance of flooding, but the car, ( 74 duster 225 1bbl fed emission) bogs from stop if you tromp on it, gradual acceleration is ok and tromp while cruising say down into passing ok, but off the line if you dont back out of the pedal it will stall, I have the pump adjustment exactly where the kit instructions say for it to be, ( 3/4" from vacuum casting to outer edge of pump rod hole), and the mixture screw is about 3 1/2 turns out I have tried winding out the mixture and I have tried opening up the loop on the pump rod will little improvement, I doubt its the fuel pump as it works fine under all other loads, any ideas?
