70scatpack FABO Gold Member FABO Gold Member Joined Oct 22, 2016 Messages 175 Reaction score 218 Location Hamburg,New York Nov 21, 2016 #1 Looking for the bolt or screw size for gas filler neck to the quarter panel on a 70 dart?
3 383Scampman Well-Known Member Joined Nov 24, 2013 Messages 1,827 Reaction score 1,060 Location New Hampshire Nov 22, 2016 #2 It is either #6 or #8 x 1/2" long . I used stainless . If you want o.e. look you can dob some flat black on after install . I would try #6 first , if they go in loose then go to #8
70scatpack FABO Gold Member FABO Gold Member Joined Oct 22, 2016 Messages 175 Reaction score 218 Location Hamburg,New York Nov 22, 2016 #3 Thanks, for the info I will try that and let you know which one works
