67Dart273
I'm sure when the make the hex ends 30* apart they most likely heat the bar and put the twist in the direction they want and then reheat treat the bar.
I am hoping that actually twisting the bar in the wrong direction didn't screw them up.
And I had more wrong than the bars on the wrong side I *THINK*. So I've got the drivers side back in and correct but I need to pull the passenger side back out and and make sure the control arms are at the bottom of the travel when I stick the bar in.
What a royal PITA.
I'm talking about "pre stressed" what I am getting at, is if they are just "made" and not "stressed" how is that materially different from reverse twisting a bar. You would think if a new, unstressed bar took a "set" that it would sag, IE you'd have to bring the car in when new after a week? month? year? 3? and have the height reset
