Hotwheels sr.
Does anyone have layout and measurements for the mounting brackets for the center console, 71 Demon? Also, anyone ever use an aftermarket shifter with a factory console? Thank you.
I'll check for that, thanksThere were pictures with measurements from various points posted. There's also a paper template available from one of our members. User name Challenger maybe? I forget. Search "console template" might help.
Cool, thanksI used a Hurst Pro-Matic (2-I think)(cant remember) Had to shave a little height off the top of the Shifter main "frame". I mounted the shifter where it was most comfortable for 1-2-3 from my driving position, then mounted console there. I ended up never re-installing any gear indicators though. Something I might fab up when I get to that point on the rebuild.
Thanks, this looks like it will help a lot.I did this quite some time back for a 67 Barracuda, the information should still be valid.
Console Conversion
Alan
AlanI did this quite some time back for a 67 Barracuda, the information should still be valid.
Console Conversion
Alan
Did you click on the thumbnails?Alan
The pictures with measurements are in a small resolution and difficult to see the numbers... do you have it on a better resolution?
