Brake booster installation
philcollins
Saint-Simon N.B., Canada
Want to install a 1973 oem brake booster on my 1971. There a "spacer w filter" that goes between the booster and master. Which way does it goes?
Face drain hole downward. That way any leaks past the MC piston won't flow into your booster. Note many newer cars have a vacuum seal there between MC and booster. Those boosters are a thin pancake shape and don't have the inner bellows on the fwd side. Brake fluid leaks in those run into the booster.
I asked because I recently put a set of fabricated valve covers on a small block and with the larger booster (which one do you have there?) they hit each other.. just a word of caution.
