BRAKE BOOSTER or not...?
scottylack
NEW JERSEY
Maybe looking for a brake booster for my 65 barracuda set up.... front discs up front from a 73 Duster and drums out back.... any thoughts on a good set up...???
or should I go manual????
I own 2 a-bodies with non-power discs. I personally, do not see the need for power assist.
One of the 2 is a 73 Dart, 4 door. It is actually the wife's car. She is more than happy with the non-power discs.
Not needed. Had a 73 master went to a 87 dodge truck manual master. Rod and all. Bolts right on with a 4 to 2 stud adapter my son made, Used the two studs that came with the master just pressed them out and installed them through the adpter from the rear. all factory mopar parts and it stops like it has pwer assist.
Manual disc brakes here too. On my 67 Dart I got the 4-2 adapter and got a master cylinder for a 85 dodge diplomat. It has the 1 1/32" bore and has a nice pedal feel.
