Brake Boosters
thunderbirds
Member
vista california
I need some help I recently purchased a new master cylinder and booster. The brake pedal is very hard, it seems like the booster is not working. I check the air line and there is plenty of vacuum, any ideal what's happening. Rich
Sounds like the booster is not working to me also.
Have you tried disconnecting the vacuum from it just to prove it feels the same?
Trailbeast and AJ/forms, Thanks for responding to my problem with the booster, I haven' t disconnecting the vacuum line but I will. Thanks again thunderbird
I need some help I recently purchased a new master cylinder and booster. The brake pedal is very hard, it seems like the booster is not working. I check the air line and there is plenty of vacuum, any ideal what's happening. Rich[/QUOT
THANKS TO ALL FOR THE ADVISE ON MY BRAKE BOOSTER, I FOUND THE PROBLEM THE LINKAGE WAS HITTING THE FIRE WALL. PROBLEM SOLVED. RECENTLY RETURNED FROM DETROIT, HAPPEN TO THERE DURING THE DREAM CRUISE DOWN WOODWARD AVE AND SAW SOME BEAUTIFUL 1968 BARRACUDAS.
Hey thunderbirds, we should get together sometime. Im in vista too!
