ecurb
just up graded my 68 fish to the 73 disc set up and proportioning valve (PV). a friend of mine said the brake light is on probably because the needle in the PV moving to the rear brakes due to starting the bleeding process with the furthest rear brake and pushing the brake pedal to hard/fast and causing the needle in the PV to move towards the rear.
he said you should try to bleed a front disc hard/fast to get the needle back over then start the bleeding process over. this time pushing on the brake pedal slowly and letting it come back naturally.
hope this makes sense to somebody. thanks as always bruce
