I completely re-did my brakes with a Wilwood setup and I've ran into quite a few issues. One of them is that pedal springs back after it's been pressed in and comes way too far back. I'm not using the factory brake switch since I have one on my portioning valve that's working great. I took a picture and it appears the switch is bent pretty bad but even if it were straightened out it doesn't seem to be where it would do any good.
Here's a shot from my brake pedal looking up:
I'm thinking I'll need to straighten that out and get a longer/adjustable pushrod. I just wanted to make sure I'm not missing anything else here since I have no idea what all is supposed to be going on down there minus the pedal itself. Does the switch double as a stopper in the stock setup?
