What do u consider major mods?? Im thinking an adjustable booster rod, a couple bolt holes in the firewall, adjustable por valve, maybe dual m/cylinder? All of which i can do at home......Thanx for ur help.....
The A-bodies all used offset linkage and bell cranks to operate a booster. B-bodies bolted them direct to the firewall. I don't think there is enough room to do that with an A-body. Making all the correct brackets and linkage sounds like way more work that I'd want to do. Why not just get an A-body set up? that should be a bolt-in.
cudamark thanx for helping......a body booster? Not able to find such a thing, maybe im not looking hard enough. Any help locating this set up would help.
You may want to talk to other '60-2 A-body owners to see if there is any clearence problems with your model otherwise I've used the '67-71 setups on the '63-6 A-bodies with only minor mods. Even the '72-6 booster might work but it's a little larger diameter. Might be worth a try if you can find one locally.
