Brand New 360/300HP Crate Motor Deal of the Week
johnmucci
moparmucci
Davenport Florida
Ok, I must sell this Brand new purchased in 2002 NEVER USED, NEVER STARTED!! 360/300HP CRATE MOTOR. IT WAS PURCHASED FROM MOPAR CONNECTION IN ATLANTA AND HAS NEVER BEEN USED. FINANCES DICTATE THAT I MUST SELL IT NOW!!! $3000 COMES WITH EVERYTHING BUT A CARB AND DIST. WOULD RATHER HAVE IT PICKED UP BUT PROBABLY COULD SHIP AT BUYERS COST! LET'S GET IT SOLD 300 HORSEPOWER 360 MAGNUM
V8 CRATE ENGINE
Why take the time and expense to rebuild your old small block when you
can bolt in a 300 horsepower Magnum engine for about the same cost?
Dyno-testing produced 300+ horsepower at 4750 rpm. Torque output is
over 375 ft.-lbs. at 4000 rpm. Perfect for mild street applications.
*P5249498 300 horsepower, V8 Magnum 360 Crate Engine
Part Number P5249498
They didn't come with build paper work. According to the advertisement in the MP catolog is what the engine came equiped with. It would be best if the seller knows the actual part number of the create engine. Then you could ethier find someone that has had one or look it up through old catologs/internet.
IIRC, IF this is a non Magnum create engine, it is a 9.0-1 rated 360 (Could very well be .020 overbored since they were seasoned blocks IIRC) MP dual plane, 308 head w/2.020/1.60 Purple cam, 284/.484. To be used with a 750 cfm carb and 1-3/4 headers to mimis the MP dyno results.
Thats IF I remember correctly.... theres been a number of create engines. But I do beileve that is how they came.
This is a Magnum Engine... I am looking for the paperwork, I will have photos and engine numbers up by tonight... It also has a deep pan as it was going to be put in a street rod. Must sell... thanks
The original 360 Commando crates (with rocker shafts) were 300hp with 1.88" intake valves and a .474" cam. The 360hp version had 2.02" intake valves, .484" cam and a single plane intake.
