Brand new 408 stroker mopar+tci torqueflite 727, great package deal!!!!
kustomautotrim
New Member
tifton ga
Rating - 0%
0   0   0
Brand New, {Only Ran on street for break in and tuning}. 408 Chrysler stroker by {Blueprint Racing engines}. Purchased brand new as a package deal from Summit. Also Brand new Torqueflite 727 TCI Super Street Fighter transmission from Summit.. Engine and trans. are all complete including all New Alternator, Hi torque starter, chrome pulleys, Fan, Procomp wires, etc..Ready to bolt in and go!
Here are specs on both.
BLOCK:
■Seasoned 360 block
■Square and parallel decked
■Align honed main bearing bore
■Cylinders honed on computer controlled machine to within .0002 straightness and roundness
■Cylinders are sonic tested for thickness
ROTATING ASSEMBLY:
■New cast steel stroker crankshaft 4.000
■Hypereutectic Keith Black pistons
■Chrysler heavy beam rods 6.123
■Hastings Moly rings Clevite Bearings
■Balanced rotating assembly
■Melling high volume oil pump
■Flat tappet hydraulic lifter camshaft
474 Int / .474 Exh & 238 Int / 238 Exh duration @ .050 - 110 degree lobe sep.
■Heavy duty double roller timing set
CYLINDER HEADS:
■Blueprint magnum cast iron heads
■Hardened retainers and springs
■1.92" swirl polished intake valves
■1.625" swirl polished exhaust valves
■Hardened push rods
A TON OF EXTRAS:
■Edelbrock AirGap Highrise Aluminum Intake
■High Volume mechanical Fuel pump
■750 cfm Holley Dual line carb
■Mallory Distributor
■MSD Coil
■Mopar Performance black satin aluminum valve covers and Air Cleaner
■Brass freeze plugs
■Dyno tested – and shipped with results
CRITICAL SPECS:
HORSEPOWER:
375 @ 5200 rpm
TORQUE:
460 @ 3900 rpm
COMP. RATIO:
9.8 to 1 (requires 91 octane fuel)
IGNITION TIMING:
34 Degrees Total (at 4000 RPM)
Torqueflite 727 trans. specs.
Stall converter TCI 2800-3200
Deep aluminum finned Summit pan
Input Spline Quantity 24
First Gear Ratio (Automatic Transmissions)
2.45
TCI Super StreetFighter transmission features are Alto Red Eagle clutches, Kolene treated steel plates, Red Eagle-lined, extra-wide Powerbands, larger diameter servo assemblies, an improved lubrication system, new sprags/roller clutches (upgraded in certain models), enhanced hard parts where applicable, increased thrust capacity, higher line pressure for extra firm shifts & greater torque capacity with less slippage, as well as being TCI factory blueprinted, inspected and dyno tested.
WELL OVER $7000 invested! SELL FOR $6250 All NEW PACKAGE DEAL READY TO BOLT IN AND GO!!
Call# 229-402-0574
pics at...
http://s1107.photobucket.com/albums/h389/kustomautotrim/408%20chrysler/
