[FOR SALE] Kb362.030 Pistons Brand New
thomasfouraker
Jacksonville
Purchased for a project that never happened. Brand new in the box. Never opened.
Just outside of Jacksonville Florida.
$350 shipped.
Press or Full floating wrist pin according to UEM
All my 360 engines are fixed pin, so I guess eather works, humm. Wondering.. !! .... let me dive into the pin and see if the weight is different, or what's the deal that la 360 pistons are pressed in..
Thank you, I have some investigation to do .
Sure thing. Let me know if you have any questions.
UEM Pistons
here are then full specs. thanks!
There it is, yep, the pin is centered, not off set..
I better pass, thank you for your time, I would pull a piston out of a box you have listed and let members see it, or at lest one out, and a shot of the open box.. yep, centered won't work for me, but can be made to work
Thought about doing that but hate breaking open the sealed factory packaging.
To clarify these pistons centered or off set will work perfectly to replace the off set oem pistons.. sorry if I confused anyone
