[SOLD] Hughes Cam and Timing Set NEW
thomasfouraker
Jacksonville
Both brand new never used.
Cam never removed from wrapper.
Timing gear removed for photos.
Hughes 6440 Timing Set $70 plus $10 shipping.
SER2226ALN-10 $380 plus $20 shipping.
Both for $450 shipped.
Located in NE Florida.
is that cam street, strip, off road spec?
Basic guidelines (These are not absolutes, just guidelines to help you get close on a cam choice)
Use: Hot street, works well with performance heads and high flow throttle body/carb, upgraded injectors a/r
Idle: Noticeable
Vacuum: mid-range
Converter: Stock to mild stall
Rear gear: Stock to 3.55
Benefits:420HP potentiel at flywheel
Requires a ECU re-programed for magnum engines
I would say it’s pretty street for a 318/360. If you put it in a stroker it would act a little smaller and the curve would start lower. You can call Hughes with your engine specs and they could give you a good idea how the cam will behave.
I’ll take the cam if you’ll separate. PM me please
Edited to add;
I PM’d you
