roylerumble
A few guys have already mentioned that if you have a flat tappet cam and mechanical lifters, you NEED the anti ware properties from high Zinc, Phosphorous, and Sulfur oils. If you have a roller cam in a modern engine, the most important thing would be to make sure you're doing frequent oil changes with a good quality oil and good quality filter (not a crappy cheep fram), no?
Any one know how they measure the amount of Z, P, S in an oil? Is it a ppm or some sort of ratio? What a good mix?
