gunmetal72
Life is a dark ride
I need to change the gear on the oil pump shaft to a bronze gear. I bought the bronze gear from comp and a new shaft from summit with the original gear. I tried to take the gear off the shaft and put the bronze on the new shaft. I had to drill a hole through the pin that holds the gear on but I kinda screwed the new shaft. Also I never got a pin with the new gear and I would have had to find one. Does anyone know where I can buy the shaft with the bronze gear already on it?
