bucket of bolts
Sedanman
67-9 Valiant specialist
chicago Il
This is a 5 gallon bucket of everything that was removeable from abodies when I parted them out. Let me know what your looking for,I'm sure I have it. I also have 2 more buckets full to dump out.
I need a spare tire hold down bolt, washer, & wing nut for an early A. Don't know if it's different than others. Also need battery hold down stuff for the same car.
I need the little keyhole studs that hold the dash speaker support frame
Nuts for them would be nice too. I can get a pic of one if you aren't familiar with. Good luck.
To make it easier to see them,I took 6 pics from top to bottom of everything spread out. There are gauge cluster screws,fender bolts,arm rest screws,body shims,K frame bolts,bumper bracket bolts,steering box bolts,shock bolts,lugs,headliner bow clips,67-9 grill & dash screws & clips,windshield trim clips & screws,heater cable clips,heater box clips,rear shock washers,exhaust manifold dish washers,door strikers,carb return springs,body plugs,dash pad nuts,this is just to name a few that I can make out from the pics. If you want pics,send me your email & I will send them so you can blow them up. There is lots of hard to find stuff that is actually from the factory & not crap made in china.
I put both buckets into 1 box which weighs #75 & is 14x14x8. Anyone want the whole box? $50 + ship from 60108
I need a vent channel guide pin bolt that inserts into the bottom of the door for a 69 barracuda???? It's about 4"-6" long that slides into the bottom of the vent window channel.
