Build Date I.D
Got the VIN and fender tag??? I'm going to see by bud over at the dealership in 20 min, He's an old school moparnut like me and has been a huge help with the Spacer..
Check your data tag.
2nd row up from bottom
2nd to last set of numbers from right.
504 = May (5th month 4th day) was the scheduled production date for the model year.
An A, B, C or D as the 1st digit would be Sept, Oct, Nov. or Dec.
A, B, C are Oct, Nov and Dec respectively
Sept is still denoted by the number 9.
Good the rest of the way on the tag location for 69 and later stuff from anywhere but 1969 Lynch Road plant
I wish I did the car was raced at one time and the inner fenders were cut out including the fender tag. The only info I have is the serial #LM23P9B380334.
Thanks
You can use a registry to maybe get your build date. If you can find a serial number before and after your car, you might be able to pin it down. This worked for my car. I found a dude with a number just after mine, and one just before.
