Build your own Blasting Cabinet
Cuda66
Austin, Texas
Parts List:
55-gallon drum w/ cover. (Free)
Siphon type "Bucket" sandblaster kit ($15) (flea market)
6x12 register adapter, 6" duct pipe & 6" duct cap. ($20)
Plexiglas window ($10)
1/4" stove bolts w/ washers & wing nuts ($5)
Old table legs (Free)
Moisture separator ($10)
Old air hose & fittings ($20)
Halogen yard lights ($25)
Blasting cabinet gloves ($25) (www.Eastwood.com)
¼” Scrap Plywood (free)
Here’s how I constructed my Blasting Cabinet.
I started with a “clean” 55-gallon drum
I cut one hole 10” wide by 6” deep in the bottom side & riveted the ductwork into it, to catch the abrasive, and where the siphon end goes.
The next hole was 16”wide by 9” tall centered for the window, and drilled holes around the perimeter to bolt the Plexiglas window to the drum. I used some of the metal cut into 1” strips at the edges of the Plexiglas to keep the Plexiglas from cracking when I bolted through it.
Cut two holes 6 1/2” in diameter 20” from center to center for the gloves, I used plywood rings as a backing plate for attaching the gloves & bolted them to the drum.
Attach lights at either end of the drum at the top angled to shine on your project.
Drill a hole to run the air hose through.
and attach it to the moisture separator.
That’s pretty much all it takes. I caulked all the edges of the window & duct work and cut a 2-1/2" round hole in each end to attach a shop vac to collect the dust at one end & let air in at the other end.
i thought about doing that with my extra 55-gallon drum, but then i paid a hundred bucks for an actual cabinet :tongue:
