SeattleQQ1Fish
I'm changing the wiring harness in my 67 Barracuda to a M&H that is modified for electronic ignition to take advantage of a dual field alternator and the newer style voltage regulator. I was surprised to see the harness is wired for a dual ballast resistor rather than the single. I'm changing to a FBO setup and need to bypass the dual ballast.
It appears that the wires running to the dual ballast are similar to my stock harness with the Mopar electronic ignition upgrade (blue and brown on one side of the ballast, and 2 blues on the other.) If I'm not mistaken, the extra green wire on the blue & brown side goes to the 5th pin on an ECU, which doesn't exist on my box. My question is, can I just snip off the connectors, splice the 2 blue wires together on one side and the blue & brown on the other and connect them to the single ballast I already have (that is jumpered with a 10 gauge wire in the back.) And what about the green wire? Can I just cut it out, or maybe splice it with the blue and brown wires to use for a 12v source for my electric choke? Thanks again, FABO
