project360 Well-Known Member Joined Sep 11, 2010 Messages 272 Reaction score 3 Location Tucson Oct 13, 2010 #1 is there a quench calculator.... is it the same as displacement volume ? thanks
C Cudafever Well-Known Member Joined Sep 27, 2009 Messages 4,870 Reaction score 1,991 Oct 13, 2010 #2 project360 said: is there a quench calculator.... is it the same as displacement volume ? thanks Click to expand... You have j heads, there is no quench pad to measure. If you had a "AKA" close chamber head. The flat spot on the head and the piston at tdc(top dead Center) with head gasket, would be you quench ###
M moper Well-Known Member Joined Dec 27, 2004 Messages 15,900 Reaction score 2,496 Location eastern CT Oct 13, 2010 #3 There is no calculator for the affect. There is only the math that gives you the amount of open space between the piston top and the head.
project360 Well-Known Member Joined Sep 11, 2010 Messages 272 Reaction score 3 Location Tucson Oct 14, 2010 #4 ok! thanks.
