DARTGAME SuPeRcHaRgEd Joined Jan 20, 2005 Messages 1,110 Reaction score 802 Location santa barbara,ca Jan 31, 2005 #1 can you use cal-tracs w/ super stock springs or would you want to?
AdamR Big Member Joined Dec 31, 1969 Messages 17,343 Reaction score 560 Location Bethel, CT Jan 31, 2005 #2 No you cant. they will work against each other.
DARTGAME SuPeRcHaRgEd Joined Jan 20, 2005 Messages 1,110 Reaction score 802 Location santa barbara,ca Jan 31, 2005 #3 thanks for the reply. what would you recomend w/500ft lbs of torque.
AdamR Big Member Joined Dec 31, 1969 Messages 17,343 Reaction score 560 Location Bethel, CT Jan 31, 2005 #4 The Super Stocks can work fine with lots of tunning but the caltracs are gonna be more consitant.
M Mopardude Well-Known Member Joined May 22, 2004 Messages 843 Reaction score 3 Location Elkhorn, WI Jan 31, 2005 #5 How does one tune a leaf spring?
AdamR Big Member Joined Dec 31, 1969 Messages 17,343 Reaction score 560 Location Bethel, CT Jan 31, 2005 #6 Clamps, shocks and ride hieght
M Mopardude Well-Known Member Joined May 22, 2004 Messages 843 Reaction score 3 Location Elkhorn, WI Jan 31, 2005 #7 Ok thats what I thought but wanted to be sure .
AdamR Big Member Joined Dec 31, 1969 Messages 17,343 Reaction score 560 Location Bethel, CT Jan 31, 2005 #8 No problem. They say adding clamps to the front segment and removing them from the rear half works.
M Mopardude Well-Known Member Joined May 22, 2004 Messages 843 Reaction score 3 Location Elkhorn, WI Jan 31, 2005 #9 Changes the way the flex I take it?
AdamR Big Member Joined Dec 31, 1969 Messages 17,343 Reaction score 560 Location Bethel, CT Jan 31, 2005 #10 Clamping the front will stiffen them up so they will hit the tires harder. It would probably make things worse on the street though.
