Valiant Steve
- Joined
- May 13, 2010
- Messages
- 186
- Reaction score
- 51
Pretty easy to cut them off take the weight off the spring and drive a wedge in between the first and second springs to spread them apart a bit so you don't cut into the main leaf while cutting the second and third springs back then clamp them after your done I used a metal strap type spring clamp just back from where I cut them off say 2" back you can see the clamp type I used in one of my pics I posted and it will work fine cut both sides if need be it will work great and that drill bit they supply with the Bars drills through the springs like they are made of butter good luck and don't sweat the small stuff your tire spin will be gone. A large screwdriver will work as a wedge, and you can get the straps at any spring shop. Best thing to use to cut the springs is a 4-1/2" angle grinder with a thin metal cut off wheel it's easy to do just take your time and wear your safety glasses sir.Thanks Steve. Cutting the leafs was not in my original line of thought but it makes sense. Looks like I'll need to cut back the 2nd leaf about 5-6 inches on both sides and (I just realized) also the 3rd leaf on the right side a couple of inches. Not something I'm really familiar with. Any tips? Anything that I should be concerned with? I really don't want to lower the height if I can avoid it.
