Calvert Springs; not happy
I have the directions and it refers you to factory specs for the caltracs. The split monoleafs showed up with no directions. I set them to 45. Been that way for 4 years. But I will check and see if I need to do 60. Thank you
People don't believe me when I tell them u bolt torque. The leaves need to be able to slide. Overtightening kills the arch and the "spring" in the spring.
Absolutely. The argument I always get is "how can the leaves slide when there is a centering pin"? Simple. The pin simply cuts the springs effectively into a front half and a rear half. The sliding action is at either end, so the center pin has nothing to do with it.
