Feb 20, 2008 #1 RAYS 69 MOPAR Well-Known Member Joined Dec 8, 2007 Messages 272 Reaction score 50 Location los angels Hi I Just Put In A Erson Cam In My Small Block I Would Like To Know Do I Have To Change The Dist. Gear???its A Flat Tappet Hyd Cam
Feb 20, 2008 #2 340demon old man Joined Apr 9, 2006 Messages 240 Reaction score 48 Location Ocean Shores, Wa do i have to NO but is good idea to change most grinders will not garranty the cam if you do not change to dist gear
Feb 20, 2008 #3 RAYS 69 MOPAR Well-Known Member Joined Dec 8, 2007 Messages 272 Reaction score 50 Location los angels What Is A Good Gear To Bye??
Feb 20, 2008 #4 Johnny Dart Well-Known Member Joined Nov 30, 2006 Messages 8,990 Reaction score 4,510 Location So Cal Unless your dist is old and worn out you are fine. Plug that bad boy in and go. In fact if you dont have electronic ignition,now would be a good time for the Mopar Performance kit.
Feb 21, 2008 #5 rumblefish360 I have escaped the EVIL Empire State! FABO Gold Member Joined Jun 21, 2005 Messages 50,497 Reaction score 24,670 Location Florida I never heard of a need to change a gear for warranty. I never did. Never a problem.
Feb 24, 2008 #6 dustertogo Well-Known Member Joined Mar 7, 2006 Messages 895 Reaction score 216 Location Brandon, MS You may be referring about the need to replace the steel distributor drive gear with an aluminum/bronze gear when installing a roller cam.
