pupjoint
pupjoint
Been reading q/a about cams and lifter set ups. I need a little help also. I have a 360 stroked to 408, running "J" heads, lunati voodoo hydraulic flat tappet cam 268/276 duration, .494/.513 lift. I want to up grade to roller rockers, would I need 1.5 or 1.6 ratio, and would the standard push rods be sufficient. The valve springs have been worked to match my cam setup. any help much appreciated.
