Cam Bearing Install Tool.
Shop, Garage and Tools
  1. krazykuda
    krazykuda FABO Gold Member FABO Gold Member
    46,860
    11861
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    11:46 AM
    He said SLOTS, not SLUTS.... :banghead:
    "No, sit down Madonna, he said biggest POSSE".... - Family Guy
  2. Dave1967
    Dave1967 Cuda crazy
    263
    91
    Nov 29, 2013
    Damascus MD
    Local Time:
    11:46 AM
    I have done about 6 sb. If you have a helper to hit the shaft for you while you keep the adapters centered and watching to make sure the cam bearing oil holes are lined up in the block, it's very easy. One trick," coat the out side of the bearings with vasoline. Works better than any other lubricant.
  3. BigBlockMopar
    BigBlockMopar BigBlockMember
    1,581
    541
    May 1, 2011
    Netherlands
    Local Time:
    6:46 PM
    I never use lubricant to install cambearings. Just tap them in dry. I want them to be stuck in there good.
    No, a bigblock mopar since that's pretty much all I do usually. Although at the moment I'm working on a 360 so maybe it's time to fab up a few more mandrels for the smallblock cam bearings (Haven't checked yet if or how much they differ from the bigblock bearings).
  4. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    10,449
    1291
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    11:46 AM
    .............My tool is like that, KD brand......they work excellent..........kim.......
  5. Bakerlite
    Bakerlite Well-Known Member
    1,395
    59
    Nov 12, 2007
    Local Time:
    5:46 AM
    Cam tunnels are too tight, or slightly out of alignment. Reaming out the bearings like that is not the ideal method.
  6. Bad Sport
    Bad Sport HALF A BUBBLE OFF Staff Member FABO Gold Member
    35,275
    14408
    Jun 12, 2010
    The Wolverine
    Local Time:
    12:46 PM
    Got home this morning and it was like Christmas. New tools, bearings, air filter, kazowey!
  7. krazykuda
    46,860
    11861
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    11:46 AM
    Way to go... :cheers:
    Now you have to play with your new toys.... :violent1: :D
  8. Bad Sport
    35,275
    14408
    Jun 12, 2010
    The Wolverine
    Local Time:
    12:46 PM
    Man, this Lisle is the cat's meow.... I have been prepping the block today and used it to remove the bearings.
    Think this bearing was bad? lmao
  9. 75Sport
    75Sport Grandpa
    1,045
    105
    Apr 22, 2010
    Michigan
    Local Time:
    11:46 AM
    Bruce I have that tool you can borrow mine if you like. Got some use but works good. Dan
  10. 75Sport
    75Sport Grandpa
    1,045
    105
    Apr 22, 2010
    Michigan
    Local Time:
    11:46 AM
    Sorry Bruce didn see that you have a shiney one.
  11. Bad Sport
    35,275
    14408
    Jun 12, 2010
    The Wolverine
    Local Time:
    12:46 PM
    Well it was. :D
